Posts in this area are restricted to the following format. If you have a general question, please post it in the Garage.
1. All new threads MUST be titled with a part number only. (i.e. 901.351.801.17)
2. Thread description should be an english description of the part. (i.e. Brake Dust Shields)
3. Replies to the thread are only restricted by pertinence. Some examples are original finish of the part (painted, cad plated, etc), common failures (cracking at the mount points), repair information or tips, pictures (stock or custom), upgrades, etc.
If you have any questions regarding the rules of this forum, please PM McMark.
> 021.109.111B, camshaft timing gear
type47
post Feb 14 2010, 11:27 AM
Viermeister
PET #
(note: will update and finish entry when I get back home)
914Mike
post Apr 13 2011, 01:02 PM
Some important marks on the cam:
Timing Mark.Attached Image
The gear size stamp.Attached Image
Putting the wrong size gear into your case will result in too much/too little lash. A too large gear will "walk" up the crank gear when test fitting on the case half. It's easiest to just note what size the gear is when you first break the case open, and make sure to put the same size back in that case. (Finding a -5 cam to replace the one in the pic that had corrosion/cracks in the gear was a multi-month journey...)
The pic in post 1 is of a -4 size. The numbers indicate size offset from standard, in 100ths of a mm. This is to accommodate differences in the dimensions of the crank and cam bores in the case.
type47   021.109.111B   Feb 14 2010, 11:27 AM
Mike914   Some important marks on the cam: Timing Mark. Th...   Apr 13 2011, 01:02 PM
- Lo-Fi Version Time is now: 3rd April 2025 - 01:27 AM
