oil pressure problem, oil light keeps coming on |
mrbubblehead |
Apr 13 2011, 07:55 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
im having a problem with my 914. the oil light for my 1.8, keeps coming on. never when the engine is cool. but after it is good and hot. it will come on when get off the freeway and sit at a stop sign. it comes on when im hard cornering. it even came on once after i was getting on the freeway at wide open throttle then immediately decelerate. i am running 20-50 wt oil. and 800 rpm idle. and oil level to the top line. but the problem gets worse as the oil level drops. im not real familiar with the type 4 engine. but know the type 1 very well.
i have a couple ideas for where the problem may lie. 1. oil pump is wore out 2. windage tray, or lack of. its not a defective oil pressure switch, i replaced it with a new one with the same result. in fact, i now have oil light and an oil pressure gauge. im pretty sure this is not normal for a type 4. but i want to ask anyways, so i can rule it out. any ideas? |
Cap'n Krusty |
Apr 14 2011, 07:55 AM
Pumps on these engines don't really wear out. Low oil pressure is generally a result of too much clearance in the bearings or the incorrect oil viscosity. Ring wear doesn't affect oil pressure, nor does compression. I recommend 20w50 Brad Penn oil. Anything other than 20w50 is too thin in most parts of the US, except in the midst of winter in the really cold states. Modern multi grade oils are fine for use in these engines.
The Cap'n |
Lo-Fi Version | Time is now: 28th September 2024 - 12:57 PM |
