oil pressure problem, oil light keeps coming on |
mrbubblehead |
Apr 13 2011, 07:55 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
im having a problem with my 914. the oil light for my 1.8, keeps coming on. never when the engine is cool. but after it is good and hot. it will come on when get off the freeway and sit at a stop sign. it comes on when im hard cornering. it even came on once after i was getting on the freeway at wide open throttle then immediately decelerate. i am running 20-50 wt oil. and 800 rpm idle. and oil level to the top line. but the problem gets worse as the oil level drops. im not real familiar with the type 4 engine. but know the type 1 very well.
i have a couple ideas for where the problem may lie. 1. oil pump is wore out 2. windage tray, or lack of. its not a defective oil pressure switch, i replaced it with a new one with the same result. in fact, i now have oil light and an oil pressure gauge. im pretty sure this is not normal for a type 4. but i want to ask anyways, so i can rule it out. any ideas? |
ConeDodger |
Apr 15 2011, 08:20 AM
Apex killer! Group: Members Posts: 23,637 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
You didn't by any chance put pipe thread sealing tape on the new sender did you?
reharvey |
Apr 15 2011, 09:16 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
You didn't by any chance put pipe thread sealing tape on the new sender did you? I had this low oil pressure problem with one of my 914s. On a hot day at idle the oil pressure light would come on. I tryed all the things suggested here but the bottom line was that the main bearings were worn out. |
Lo-Fi Version | Time is now: 28th June 2024 - 09:35 AM |
