kconway |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,347 Joined: 6-December 04 From: Monrovia, CA Member No.: 3,231 Region Association: Southern California ![]() |
I have an non-functioning odometer and figured one of the gears inside was broken. Following the Pelican DIY article I carefully opened it up expecting to find something broken. I don't see anything out of the ordinary but I've never been inside before.
With the trip reset cable inserted in the speedo port I spun it up with a drill. The speedo works just fine but the mile don't increment on the odometer. The trip reset works when turned except I can never get it to 0000. The "ones" column never turns to 0. Anybody see anthing out of the ordinary or is this just a lost cause? Kev ![]() ![]() ![]() |
patssle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None ![]() |
I have the same problem, everything looks perfect, but I do believe my gray wheel doesn't spin either. I think glue or something would fix it?
Lo-Fi Version | Time is now: 26th June 2024 - 04:55 AM |
