Engine Quiestion..P&C's. |
MikeM |
Apr 26 2011, 05:47 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hello all...I was examing bills from previous owners of my car, which is a 1974 2.0 liter 914, LE. It appears that one PO had the pistons and cylinders replaced with bus parts that are 94mm. I don't have the part number here at work but I did some quick searching earlier and it looks like they are indeed bus parts.
Question is...how should this engine be "driveability" wise? What should it feel like? How would it be with proper 914 pistons? Would I notice a difference? Would it be worth changing them? The car has only done about 6000 miles since the pistons were installed. Oh..GA case and working D-jet. Thanks as always... Mike |
r_towle |
Apr 26 2011, 08:47 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
stock versus what you have (if they are bus pistons) is 10-15 hp difference.
It runs, it starts...drive it like you stole it. If and when you decide you want more power, you are limited to about 25hp increase...which is alot considering you are running less than 100 right now... Will you feel it..yes, for a bit. Its kinda like a computer...a new one seems really fast...for a while. then is just normal. Sure, you can rebuild it, but it may be something to plan out to add some real HP and do a few more things while you are there.. I would not bother to change the pistons and cylinders only in your specific case...but that is just my opinion. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 07:28 AM |
