Stock exhaust photos, four-cylinder, that is... |
Dave_Darling |
Apr 9 2004, 11:01 AM
914 Idiot Group: Members Posts: 14,992 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Every once in a while, I get asked questions about the differences between the various exhausts that came on stock four-cylinder 914s. I have taken a number of pictures, but cannot seem to find the best ones for the 1.7 and (early) 2.0 exhaust. But this is what I have. I would appreciate it if someone would help out by providing better pics if they have them.
Anyway, let's start out with the 1.7 exchangers. They were also used on the 1974-only 1.8 cars, but it's easiest simply to call them "1.7 exchangers". The ones in this pic are SSIs, but you can (hopefully) see that they lift up off the ground back between the heat exchanger wrapping and the muffler flange. (And yes, this is one that I'd like a better pic of.) Attached image(s) |
Dave_Darling |
Apr 9 2004, 11:04 AM
Finally, we have the "late" exhaust. This was used on all of the 75-76 914s, 1.8 and 2.0 both. Note that it is a two-piece affair, with one part that bolts to the heads and joins together in a single tube, then another part that bolts to that and has the heat-exchanger wrapping on it. The muffler flange, as a result, is triangular instead of trapezoid-shaped like the earlier ones.
Attached image(s) |
Lo-Fi Version | Time is now: 20th June 2024 - 05:35 AM |
