Just another damned project thread, 914-6 3.2 conversion in GT dress-up |
ConeDodger |
Apr 2 2011, 03:15 PM
Apex killer! Group: Members Posts: 23,638 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
First of all, let me say this: let's not turn this into a 4 vs: 6 thread. I like them both and really don't give a damn about your position on this non-issue.
All the legal stuff out of the way, let's talk engine. First of all, this project is well advanced. The engine is already together and the 20 minute cam run in has been done. But let's talk about how we got to that point first... This motor is a 2432 Raby kit. It uses the LE200 heads and stock 2liter cylinders. The stroked crank is 84mm I believe so think of it as a super-stroker. It will run Jenvey throttle bodies and SDS injection. The EFI sensors I have chosen to use will be TPS, CHT, MAP, IAT, O2 in closed loop, and I think that is everything. Injectors are Ford Red Top. This motor requires quite a bit of engine block clearance so as they say, don't try this at home... It took me about three trips down to Original Customs to put the engine together. I used McMark's shop so I could get his free advice which he of course charges me for, and I don't get distracted by wives wondering how much all of this costs. Plus Mark has an engine break-in stand that allows us to fire it out of the car and correct anything that might be wrong without having to pull an already installed motor. Here is a dyno sheet of one of these motors that Jake actually built. I would expect that my result might be within 10% of his. :Insert fingers crossed smiley here: Attached thumbnail(s) |
McMark |
Apr 28 2011, 11:33 AM
True. I usually remember to include that caveat. SDS obviously works well. There are plenty of cars out there with it. The system simply doesn't live up to my aesthetic demands, which I'll be the first to admit are a bit over-bearing. But I want things to look nice, as well as function properly. (IMG:style_emoticons/default/wink.gif)
Zimms |
Apr 28 2011, 11:45 AM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
True. I usually remember to include that caveat. SDS obviously works well. There are plenty of cars out there with it. The system simply doesn't live up to my aesthetic demands, which I'll be the first to admit are a bit over-bearing. But I want things to look nice, as well as function properly. (IMG:style_emoticons/default/wink.gif) So is this a possible additional product? I would be interested. I have a 2270 Raby kit waiting in my basement, and I plan on doing SDS with ITB's source yet undetermined. Nice build Rob and Mark. I am loving this thread. |
ConeDodger |
Apr 28 2011, 11:58 AM
True. I usually remember to include that caveat. SDS obviously works well. There are plenty of cars out there with it. The system simply doesn't live up to my aesthetic demands, which I'll be the first to admit are a bit over-bearing. But I want things to look nice, as well as function properly. (IMG:style_emoticons/default/wink.gif) So is this a possible additional product? I would be interested. I have a 2270 Raby kit waiting in my basement, and I plan on doing SDS with ITB's source yet undetermined. Nice build Rob and Mark. I am loving this thread. I think Mark definitely plans to do this again... I often end up his guinea pig in his quest for knowledge! (IMG:style_emoticons/default/blink.gif) The source I used were actually someone else's cast-off project stuff. But for your reference the Throttle bodies are Jenvey out of England I think. The manifolds are the same as the common carb manifolds. All other sensors are available through SDS. |
Lo-Fi Version | Time is now: 28th June 2024 - 11:12 PM |
