> JOE's Hershey Emergency Thread, oooohhhhhh nnnoooooooo
jsayre914
post Apr 22 2011, 05:21 PM
Speed Up !!!
(IMG:style_emoticons/default/sad.gif)
Just about 30 min ago i got stuck in traffic on 83, there was an accident. I was in stop and go for about 10-15min. My car has been making a noise kinda like a compression ticking sound from the drivers side. But today it really started acting funny. The idle was dropping in and out in traffic, and when i went to move foreward each time... the car was shaking (violent) like it was running on 2 cylindrs. I kept revving it up to keep it smoothed out. When i got out of the jam, it seemed to come back once i got up to speed, but again when i hit a red light.
I am at work right now so i cant actually trouble shoot.
I did pull each wire of the plugs and it did not stumble on the drivers side rear plug. It did however stumble when i pulled the injector wire off the same cylnder
(IMG:style_emoticons/default/WTF.gif)
Valves were just adjusted last week.
I WILL MAKE IT TO THE EVENT !!
any advise would be greatly appreaciated.
p.s.
Its raining (IMG:style_emoticons/default/dry.gif)
scotty b
post May 10 2011, 05:18 PM
rust free you say ?
Joe, my machinist down here is really good and used to own a shop building type 1 and type 4 engines in the 70-80's. RIMJOb....errrrrrr RIMCO should make good BUT, Worst case, give them to me. Danny isn't cheap, But he is damn good and a damn anal machinist. He is the ONLY guy in town I trust to do aircooled engine machining
jsayre914   JOE's Hershey Emergency Thread   Apr 22 2011, 05:21 PM
vsg914   If you still have points, check dwell and timng. H...   Apr 22 2011, 05:43 PM
sww914   Sounds exactly like a bad spark plug wire to me.   Apr 22 2011, 05:44 PM
jsayre914   its got pertronix. 1.8 liter with L-jet the wire ...   Apr 22 2011, 05:47 PM
Gint   Could be a lot of things, but it sounds like ignit...   Apr 22 2011, 07:19 PM
r_towle   make sure all your fuel injectors are plugged in t...   Apr 22 2011, 07:34 PM
jsayre914   just made it home. :chow: that ride sucked! ...   Apr 22 2011, 08:47 PM
jsayre914   Intake valve was almost 2 full turns to tight :bli...   Apr 22 2011, 10:30 PM
ppetion   :( :( :( :( We are waiting for the results........   Apr 22 2011, 10:49 PM
jsayre914   ALL 4 are BANGING!!! :Qarl: :Qarl: ...   Apr 22 2011, 11:02 PM
avidfanjpl   I know all about badly adjusted valves. My car ra...   Apr 22 2011, 11:13 PM
euro911   My wife's 1.7L ran 'OK' when we acquir...   Apr 23 2011, 01:06 AM
tomeric914   Glad you found the problem and fixed it Valves we...   Apr 23 2011, 09:31 AM
jsayre914   Car ran great on the way home from hershey. I then...   Apr 25 2011, 09:31 PM
r_towle   check the adjustment again. Two things....did you...   Apr 26 2011, 03:54 PM
ppetion   The sound system needs the other 2 cylenders to ru...   Apr 26 2011, 04:03 PM
jsayre914   The sound system needs the other 2 cylenders to r...   Apr 27 2011, 01:10 PM
jsayre914   I started to drop the engine last night, but then ...   Apr 27 2011, 01:08 PM
Vacca Rabite   You got a lot done in an hour. All that usually ta...   Apr 27 2011, 01:52 PM
Eric_Shea   The valve seat you dropped. ;)   Apr 27 2011, 02:13 PM
jsayre914   The valve seat you dropped. ;) read carefully...   Apr 27 2011, 03:13 PM
r_towle   if you are planning to remove the heads...its obvi...   Apr 27 2011, 02:30 PM
r_towle   a seat that is getting beat into the head would al...   Apr 27 2011, 03:56 PM
jsayre914   i am pulling the head either tonight or tommorow d...   Apr 27 2011, 04:22 PM
Dr Evil   :popcorn: I am so proud of you doing this on your...   Apr 27 2011, 06:21 PM
jsayre914   Looks like my intake seat has been hammerd inward ...   May 10 2011, 10:19 AM
jsayre914   the head Number 2 Number 1   May 10 2011, 10:20 AM
jsayre914   the seat the good side   May 10 2011, 10:22 AM
Vacca Rabite   I see head leaks too. You really won't like th...   May 10 2011, 10:33 AM
jsayre914   I see head leaks too. You really won't like t...   May 10 2011, 11:09 AM
type47   You really won't like the probable cause. :( ...   May 10 2011, 02:27 PM
jsayre914   I just checked the old thread.... YUP its the exac...   May 10 2011, 11:48 AM
Cap'n Krusty   I have to repeat myself once again. There are goo...   May 10 2011, 05:16 PM
scotty b   Joe, my machinist down here is really good and use...   May 10 2011, 05:18 PM
jsayre914   so what is the verdict? Rimco did a pisspoor job ...   May 10 2011, 05:37 PM
saigon71   Bummer on that valve seat Joe, but at least Rimco ...   May 10 2011, 06:53 PM
jsayre914   Bummer on that valve seat Joe, but at least Rimco...   May 10 2011, 07:19 PM
ppetion   Why r we blaming rimco? it'scaused by vibratio...   May 10 2011, 08:48 PM
jsayre914   So...... :popcorn: ........ :( ........... :popcor...   May 16 2011, 03:15 PM
jsayre914   Just called me back 6pm May 16 two thousand and el...   May 16 2011, 04:05 PM
saigon71   Man, they are giving you a good "rimming....   May 16 2011, 04:23 PM
jsayre914   Man, they are giving you a good "rimming....   May 16 2011, 05:18 PM
saigon71   Man, they are giving you a good "rimming....   May 16 2011, 06:13 PM
type47   You need to surf more throughly, you missed mepste...   May 16 2011, 05:47 PM
jsayre914   Your gonna love this shit :D :rotfl: I got the ...   May 18 2011, 10:38 AM
jsayre914   This might help you understand. :first:   May 18 2011, 10:51 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 05:28 PM
