> Jack Post Repair Question
saigon71
post May 6 2011, 03:33 PM
I welded a new jack tube on to the replacement wheelhouse section from Restoration Design today, aligning it perfectly with the square hole that came pre-punched in the new panel. When I started fitting the jack post brace, I had to adjust the bends on it by about 1/8" to get it to fit right. I am having a hard time getting accurate measurements from the old chunk of long I have because it is a disaster.
The question is, how reliable is the pre-punched guide hole? Should I just roll with it? Anyone else run into something similar?
Thanks in advance.
Pics:
TargaToy
post May 9 2011, 08:15 PM
-NONSOLIS RADIOS SEDIOUIS FULMINA MITTO-
I just wish somebody made the same wheelhouse parts for the driver's side. Mine was nearly as rotten on that side as the PS and I had to make all of that area myself before adding the RD jack post. It's been very time consuming. ...but rewarding! (IMG:style_emoticons/default/biggrin.gif)
scotty b
post May 10 2011, 05:35 PM
rust free you say ?
QUOTE(TargaToy @ May 9 2011, 06:15 PM) *
(IMG:style_emoticons/default/agree.gif) I am seeing more and more rotted drivers sides that people want repaired. Mike (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif)
saigon71   Jack Post Repair Question   May 6 2011, 03:33 PM
TargaToy   Everything "reproduction" I ever buy req...   May 6 2011, 07:48 PM
saigon71   Everything "reproduction" I ever buy re...   May 6 2011, 11:00 PM
rhcb914   Moving the bends 1/8 of an inch is NOTHING! Th...   May 7 2011, 07:03 AM
tomeric914   I don't think your getting good weld penetrati...   May 7 2011, 07:25 AM
saigon71   I don't think your getting good weld penetrat...   May 7 2011, 11:28 AM
draganc   I don't think your getting good weld penetra...   May 7 2011, 02:52 PM
Spoke   When I replaced the jack point on the passenger si...   May 7 2011, 07:46 AM
ppetion   Nice , I have to do one of mine soon.   May 7 2011, 12:58 PM
TargaToy   Hey, by the way. Did you know that wheelhouse sec...   May 7 2011, 07:00 PM
saigon71   Hey, by the way. Did you know that wheelhouse se...   May 7 2011, 08:45 PM
saigon71   Hey, by the way. Did you know that wheelhouse s...   May 9 2011, 02:10 PM
scotty b   Hey, by the way. Did you know that wheelhouse se...   May 7 2011, 08:56 PM
scotty b   i normally put the long on then fit the jack post ...   May 7 2011, 08:36 PM
saigon71   i normally put the long on then fit the jack post...   May 7 2011, 08:59 PM
avidfanjpl   I recommend ONLY Restoration Design from Canada...   May 7 2011, 09:05 PM
saigon71   Checked the fit of the outer fiberglass long with ...   May 8 2011, 06:58 PM
jaxdream   I welded a new jack tube on to the replacement wh...   May 8 2011, 10:13 PM
saigon71   I welded a new jack tube on to the replacement w...   May 9 2011, 02:12 PM
TargaToy   Here's what the two pieces from RD look like. ...   May 9 2011, 04:32 PM
saigon71   Here's what the two pieces from RD look like....   May 9 2011, 05:25 PM
retro74   Here's what the two pieces from RD look like....   Jul 21 2011, 07:54 PM
retro74   Here's what the two pieces from RD look like...   Jul 28 2011, 07:08 AM
TargaToy   I just wish somebody made the same wheelhouse part...   May 9 2011, 08:15 PM
saigon71   I just wish somebody made the same wheelhouse par...   May 10 2011, 06:19 AM
scotty b   I just wish somebody made the same wheelhouse par...   May 10 2011, 05:35 PM
peteyd   The two pieces now come spot welded together   Jul 28 2011, 08:32 AM
saigon71   The two pieces now come spot welded together ...   Jul 28 2011, 01:56 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:26 PM
