> How do you fix a 1.8 w Ljet, that is running too lean
jsayre914
post May 12 2011, 04:20 PM
Speed Up !!!
After seeing the inside of my head, it seems that I have a lean condition. What causes the Lean condition and how can I fix it?
1.8 bone stock with L-jet
jcd914
post May 12 2011, 05:49 PM
There is a mixture adjustment screw on the air flow meter. It works by opening or closing a bypass so more or less air flows past the flap in the air flow meter. It's enfluence is primarly at idle and low speed.
Before you pop the top off your air flow meter and start adjusting the wiper and/or spring make sure you don't have vacuum leaks and the engine is tuned properly (pts, plugs, valve adjustment, etc...).
It took me seveal days working on it to get the air flow meter adjusted back close to stock after someone had "fixed" on my VW bus.
Jim
Drums66
post May 17 2011, 11:56 AM
914 Rudiments
QUOTE(jcd914 @ May 12 2011, 04:49 PM) *
Jim
......You can do this but.........I wouldn't go under the lid(Real pros..say don't) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/popcorn[1].gif)(unless you really know what you are doing)
- Lo-Fi Version Time is now: 23rd December 2024 - 03:20 AM
