Spoilers, SCCA legal |
Randal |
May 22 2011, 09:38 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
Down at AAS yesterday. All the modified cars had huge spoilers. I thought 8" was the limit, but it looked more like a foot. Got to figure out what is legal and get one of those puppies on 222. |
PeeGreen 914 |
May 23 2011, 09:20 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
I know some use big ol airdams with splitters but why not just use an LE style with a splitter? Is it better if it is lower? I know the idea is to keep air out from the underside but wouldn't the benefit of the splitter be more beneficial? That way it would still be able to handle more roads, driveways, trailers...
jjackson |
May 24 2011, 05:20 AM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
I know some use big ol airdams with splitters but why not just use an LE style with a splitter? Is it better if it is lower? I know the idea is to keep air out from the underside but wouldn't the benefit of the splitter be more beneficial? That way it would still be able to handle more roads, driveways, trailers... Air pushes down on splitter front and also creates negative air space under at backside-the further back you go the better.Test in mag did not adjust heights (from ground) of splitters. We went as low as we could-still being able to load-ramp extensions cost me 350. More than we had in the whole splitter,air dam, and hardware.Could have done it with boards but sometimes already look like the Clampetts. (IMG:style_emoticons/default/sheeplove.gif) JJackson |
PeeGreen 914 |
May 24 2011, 11:19 AM
I know some use big ol airdams with splitters but why not just use an LE style with a splitter? Is it better if it is lower? I know the idea is to keep air out from the underside but wouldn't the benefit of the splitter be more beneficial? That way it would still be able to handle more roads, driveways, trailers... Air pushes down on splitter front and also creates negative air space under at backside-the further back you go the better.Test in mag did not adjust heights (from ground) of splitters. We went as low as we could-still being able to load-ramp extensions cost me 350. More than we had in the whole splitter,air dam, and hardware.Could have done it with boards but sometimes already look like the Clampetts. (IMG:style_emoticons/default/sheeplove.gif) JJackson I was thinking of taking a sheet of steel, taking it back to the belly pan, and attaching the struts of the splitter to the body of the car while the car rather than the airdam. Thoughts? (IMG:style_emoticons/default/confused24.gif) |
jjackson |
May 24 2011, 12:04 PM
I was thinking of taking a sheet of steel, taking it back to the belly pan, and attaching the struts of the splitter to the body of the car while the car rather than the airdam. Thoughts? (IMG:style_emoticons/default/confused24.gif) [/quote] Ran bolts through original mount points of air dam-ran nut down secure-second nut at back to turnbuckles.Also attached using L brackets at back side of air dam.Was going to run bolt and spacer through splitter to bottom of front trunk-Have not done last one-so far it has withstood some good impacts with no problem.This air dam that I mentioned earlier is heavier made than any I've seen.Broken every air dam I've ever run until this one.Since I just typed that, I think I will add the additional supports.We are currently running "alucobond" panel for splitter-aluminum with resin sandwich-about 1 lb per sq foot-Car really liked that weight there.I'll try to get pix this pm.JJackson |
Lo-Fi Version | Time is now: 6th January 2025 - 10:51 PM |
