thenewwazoo |
Member ![]() ![]() Group: Members Posts: 56 Joined: 3-October 09 From: RWC Member No.: 10,883 Region Association: Northern California ![]() |
Does anyone have, or can anyone point me to the parts (enclosure, seals, pins, even a pigtail would be... acceptable) to let me connect to the stock harness' 14-pin relay board plug (T14)? I'm removing my relay board but don't want to cut the stock harness to replace the 14-pin connector.
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have several 14 pin connectors that fit the 914 fuse/relay panel. I cut them out of an Audi at pick N Pull several years ago, think it was an 1989/90 Audi 5000 turbo. Audi used them to connect multiple harnesses together in the driverside kick panel. I think there were 6 pair (male & female) mounted to 1 bracket.
Jim |
thenewwazoo |
I have several 14 pin connectors that fit the 914 fuse/relay panel. I cut them out of an Audi at pick N Pull several years ago, think it was an 1989/90 Audi 5000 turbo. Audi used them to connect multiple harnesses together in the driverside kick panel. I think there were 6 pair (male & female) mounted to 1 bracket. Jim You wouldn't happen to have one left over, wouldja? (IMG:style_emoticons/default/smile.gif) |
jcd914 |
I have several 14 pin connectors that fit the 914 fuse/relay panel. I cut them out of an Audi at pick N Pull several years ago, think it was an 1989/90 Audi 5000 turbo. Audi used them to connect multiple harnesses together in the driverside kick panel. I think there were 6 pair (male & female) mounted to 1 bracket. Jim You wouldn't happen to have one left over, wouldja? (IMG:style_emoticons/default/smile.gif) I never used any of them, don't even remember what project I got them for. I came accross them a month or so ago but I'm not sure where I put them. I checked the electrical drawer in the toolbox but they were not there. I'll look out in the shed when I have some time, probably this weekend. Anyone else need one? Jim |
Lo-Fi Version | Time is now: 28th June 2024 - 07:28 PM |
