Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
I laid my wiring harness back in the car last weekend and have a question about the brown and brown/white white that leaves the main wiring harness just after the firewall in the front trunk.
What does it terminate to? It continues down to the brake master cylinder pressure fail switch. I know what to do with it there - but what does it attach to up top? I am working on a early '72 model year. Thanks in advance! |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
1. Can you double-check the colors? From the picture it seems that none of the wires is white.
2. Are you sure you routed the wires the right way? It looks like the buzzer and door open switch would connect to that white and brown wires but that's located under the dash. |
Kansas 914 |
1. Can you double-check the colors? From the picture it seems that none of the wires is white. 2. Are you sure you routed the wires the right way? It looks like the buzzer and door open switch would connect to that white and brown wires but that's located under the dash. Hi Valy, Thanks for the reply. Here is a picture (definitley BRN/WHT). These wires are for sure located in the right spot as the grommet for the main harness that goes through the firewall was never removed so these are on the correct side of the firewall. ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 06:03 AM |
