Wire Harness question, Brown/White near brake reservoir |
Kansas 914 |
May 27 2011, 10:35 AM
Advanced Member Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains |
I laid my wiring harness back in the car last weekend and have a question about the brown and brown/white white that leaves the main wiring harness just after the firewall in the front trunk.
What does it terminate to? It continues down to the brake master cylinder pressure fail switch. I know what to do with it there - but what does it attach to up top? I am working on a early '72 model year. Thanks in advance! |
Kansas 914 |
May 27 2011, 02:37 PM
The Brown/White at this location and the Brown/White at the MC are wired in parallel making me think that this was indeed wired (from the factory) for a pressure cap at the fluid reservoir. If either switch closed then the warning lamp would come on.
SirAndy |
May 27 2011, 04:41 PM
Resident German Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The Brown/White at this location and the Brown/White at the MC are wired in parallel making me think that this was indeed wired (from the factory) for a pressure cap at the fluid reservoir. If either switch closed then the warning lamp would come on. Interesting! (IMG:style_emoticons/default/idea.gif) You should probably tape those off ... (IMG:style_emoticons/default/popcorn[1].gif) |
Kansas 914 |
May 27 2011, 04:59 PM
Interesting! (IMG:style_emoticons/default/idea.gif) You should probably tape those off ... (IMG:style_emoticons/default/popcorn[1].gif) I will tape them off - but I wll also bring them up near the top of the fluid reservoir cap (or to a place I can grab them) just in case we discover more about this oddity in the future. Thanks for all your help - I thought I had lost my mind - cheers! |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:10 PM |
