> Fuel Pump will not run, Checked fuse, relay, etc
BCinSC
post May 29 2011, 08:42 AM
Nothing but Trouble
So Blanche ('73 White 914-4 1.7L) was running great last summer until she simply stopped on I-95 in Burlington, MA. Simply no spark anymore. Having no time to deal with it, she sat until today. I figured out the spark problem, but now the fuel pump, won't. Familiar with this type of issue, I open the relay board and check the fuse and the relay. I've got 12V where I'm suppose to - both sides of fuse, pin85 of FP relay when key on (FI Brain energizes to close circuit to join pin30 and pin87 I believe). PIN13 of connector closest to firewall, which diagram says goes out to FP itself, shows continuity to ground, so I'm guessing broken wire somewhere. Sounds reasonable/plausible? Fuel Pump was functional before I put her away.
BCinSC
post May 29 2011, 01:36 PM
Nothing but Trouble
I reiterate that I was doing 60+ on the highway when she died. Tach just went to zero and no more power. Coasted to shoulder, where she would crank, but not catch. Same today.
BCinSC   Fuel Pump will not run   May 29 2011, 08:42 AM
SLITS   Pumps do gum up or fail. Run hot wire to + termin...   May 29 2011, 09:05 AM
Elliot Cannon   Pumps do gum up or fail. Run hot wire to + termi...   May 29 2011, 09:13 AM
SLITS   Pumps do gum up or fail. Run hot wire to + term...   May 29 2011, 09:37 AM
Elliot Cannon   [quote name='Elliot Cannon' post='1485200' date='...   May 29 2011, 01:38 PM
BCinSC   Is that Gumby with a Blunt? Anyway, I think you a...   May 29 2011, 09:12 AM
Tom   Bruce, Just went thru this yesterday with anot...   May 29 2011, 09:12 AM
BCinSC   Argh. Swapped pumps and same deal. Could FI Brai...   May 29 2011, 10:11 AM
SLITS   Argh. Swapped pumps and same deal. Could FI Bra...   May 29 2011, 10:16 AM
BCinSC   I don't get it. I have 12V at Pin30 of Relay....   May 29 2011, 10:26 AM
BCinSC   Mess with it long enough, and miraculously, it wil...   May 29 2011, 10:34 AM
Tom   The relays sometimes don't fit tight in the so...   May 29 2011, 10:51 AM
BCinSC   Not quite the contortionist I used to be. Can...   May 29 2011, 12:09 PM
BCinSC   Hooked up known good spark plug to wire #1 and cra...   May 29 2011, 12:17 PM
benalishhero   No spark? Are you running points and condensor?   May 29 2011, 01:03 PM
BCinSC   Yes. Both relatively new (couple thousand miles a...   May 29 2011, 01:34 PM
BCinSC   I reiterate that I was doing 60+ on the highway wh...   May 29 2011, 01:36 PM
Elliot Cannon   I just had a crap load of electrical problems with...   May 29 2011, 01:42 PM
BCinSC   Checked points more closely and found that the met...   May 29 2011, 02:59 PM
djm914-6   Sounds like you're having fun. WHo's watch...   May 29 2011, 03:08 PM
BCinSC   Kids in Maine. 3 dogs in kennel. Other 4 milling...   May 29 2011, 06:36 PM
djm914-6   That's odd.... was the registry open today?   May 29 2011, 06:57 PM
- Lo-Fi Version Time is now: 27th December 2024 - 05:58 AM
