> Fuel Pump will not run, Checked fuse, relay, etc
BCinSC
post May 29 2011, 08:42 AM
Nothing but Trouble
So Blanche ('73 White 914-4 1.7L) was running great last summer until she simply stopped on I-95 in Burlington, MA. Simply no spark anymore. Having no time to deal with it, she sat until today. I figured out the spark problem, but now the fuel pump, won't. Familiar with this type of issue, I open the relay board and check the fuse and the relay. I've got 12V where I'm suppose to - both sides of fuse, pin85 of FP relay when key on (FI Brain energizes to close circuit to join pin30 and pin87 I believe). PIN13 of connector closest to firewall, which diagram says goes out to FP itself, shows continuity to ground, so I'm guessing broken wire somewhere. Sounds reasonable/plausible? Fuel Pump was functional before I put her away.
djm914-6
post May 29 2011, 06:57 PM
Happiness is: Getting on the road
That's odd.... was the registry open today?
BCinSC   Fuel Pump will not run   May 29 2011, 08:42 AM
SLITS   Pumps do gum up or fail. Run hot wire to + termin...   May 29 2011, 09:05 AM
Elliot Cannon   Pumps do gum up or fail. Run hot wire to + termi...   May 29 2011, 09:13 AM
SLITS   Pumps do gum up or fail. Run hot wire to + term...   May 29 2011, 09:37 AM
Elliot Cannon   [quote name='Elliot Cannon' post='1485200' date='...   May 29 2011, 01:38 PM
BCinSC   Is that Gumby with a Blunt? Anyway, I think you a...   May 29 2011, 09:12 AM
Tom   Bruce, Just went thru this yesterday with anot...   May 29 2011, 09:12 AM
BCinSC   Argh. Swapped pumps and same deal. Could FI Brai...   May 29 2011, 10:11 AM
SLITS   Argh. Swapped pumps and same deal. Could FI Bra...   May 29 2011, 10:16 AM
BCinSC   I don't get it. I have 12V at Pin30 of Relay....   May 29 2011, 10:26 AM
BCinSC   Mess with it long enough, and miraculously, it wil...   May 29 2011, 10:34 AM
Tom   The relays sometimes don't fit tight in the so...   May 29 2011, 10:51 AM
BCinSC   Not quite the contortionist I used to be. Can...   May 29 2011, 12:09 PM
BCinSC   Hooked up known good spark plug to wire #1 and cra...   May 29 2011, 12:17 PM
benalishhero   No spark? Are you running points and condensor?   May 29 2011, 01:03 PM
BCinSC   Yes. Both relatively new (couple thousand miles a...   May 29 2011, 01:34 PM
BCinSC   I reiterate that I was doing 60+ on the highway wh...   May 29 2011, 01:36 PM
Elliot Cannon   I just had a crap load of electrical problems with...   May 29 2011, 01:42 PM
BCinSC   Checked points more closely and found that the met...   May 29 2011, 02:59 PM
djm914-6   Sounds like you're having fun. WHo's watch...   May 29 2011, 03:08 PM
BCinSC   Kids in Maine. 3 dogs in kennel. Other 4 milling...   May 29 2011, 06:36 PM
djm914-6   That's odd.... was the registry open today?   May 29 2011, 06:57 PM
10 User(s) are reading this topic (10 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 06:09 AM
