johnnyfast |
Newbie ![]() Group: Members Posts: 3 Joined: 24-May 11 From: westchester, ca Member No.: 13,114 Region Association: Southern California ![]() |
I have 3 problems that i need help with plz i have a 74 Porsche 914 1.8
1. the fuel pump will turn on as soon as i turn the key and it wont stop. is that normal? if not then how long is it suppose to stay on ? and how can fix it 2. My turn signals stay on after i turn the car off unless i return the lever to the middle position. is that normal? 3. the rpms are low to the point that sometimes it will turn off. how can i adjust? thanks johnny |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,699 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I have 3 problems that i need help with plz i have a 74 Porsche 914 1.8 1. the fuel pump will turn on as soon as i turn the key and it wont stop. is that normal? if not then how long is it suppose to stay on ? and how can fix it 2. My turn signals stay on after i turn the car off unless i return the lever to the middle position. is that normal? 3. the rpms are low to the point that sometimes it will turn off. how can i adjust? (IMG:style_emoticons/default/welcome.png) 1. Depends on what you're running. Stock L-Jet FI? Carbs? Any modification we should know about? 2. Yes. It's a feature, not a bug. Most all European cars behave the same way, it's a "parking light" that you control with your turn signal lever. 3. Too many possibilities to list here. We need more info. When was the last time the valves were adjusted? Stock engine? Carbs? FI? (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:22 PM |
