HELP!, Now recharging batteries in Albert Lea, MN |
rnellums |
May 30 2011, 07:20 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
SO my teener broke down as I was driving out of South Dakota. I was able to get it towed for free to Mitchell, SD. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
Here is what is broken: The bolt that attaches the Impeller hub to the crankshaft has sheared off inside the crankshaft. This caused the impeller hub to fall off the crankshaft and caused the generator to stop functioning as well as engine cooling to cease. Once the hub fell off the crankshaft, the woodruff key fell out too. Here is my situation: the car is parked at a transmission shop here in Mitchell. I have a full set of sockets and wrnches, as well ass assorted 914 tools, but no jacks or jackstands. I have removed the forward engine tin, as well as the belt, impeller and hub. I have also removed the front half of the impeller shroud. My plan of attack: I want to ask the transmission shop to use an extractor to remove what is left of the bolt with the engine still in the car. if they can remove it I will need to locate a new woodruff key, at which point I should be able to re-install the impeller using a new bolt and a lockwasher since the old bolt is shot. (IMG:style_emoticons/default/driving.gif) My Plan B: if I can't remove what is left of the bolt, I plan to rent a U Hauls truck and trailer and pull the car the rest of the way to Muncie, Indiana. I would really appreciate some input on whether my reasoning is sound, if I'm an imbecile, or if I'm SOL thanks in advance, Ross |
rick 918-S |
May 30 2011, 09:29 PM
Hey nice rack! -Celette Group: Members Posts: 20,679 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Anyone know how much a oneway rental for a u-haul would cost from Mitchell to Muncie? That's close to 900 miles. plus gas...(IMG:style_emoticons/default/wacko.gif)
I would try to fix it if I were you. Even if you had to hire a stall in the tranny shop and pay their guys to help for the day. If nothing is damaged except a bolt you can get a woodruff key at the hardware store. PM me if you need parts. I'm about 6 hours away if your desperate and UPS will do one day shipping from here. I'll pm you my cell. |
Lo-Fi Version | Time is now: 25th September 2024 - 10:49 PM |
