rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
SO my teener broke down as I was driving out of South Dakota. I was able to get it towed for free to Mitchell, SD. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
Here is what is broken: The bolt that attaches the Impeller hub to the crankshaft has sheared off inside the crankshaft. This caused the impeller hub to fall off the crankshaft and caused the generator to stop functioning as well as engine cooling to cease. Once the hub fell off the crankshaft, the woodruff key fell out too. Here is my situation: the car is parked at a transmission shop here in Mitchell. I have a full set of sockets and wrnches, as well ass assorted 914 tools, but no jacks or jackstands. I have removed the forward engine tin, as well as the belt, impeller and hub. I have also removed the front half of the impeller shroud. My plan of attack: I want to ask the transmission shop to use an extractor to remove what is left of the bolt with the engine still in the car. if they can remove it I will need to locate a new woodruff key, at which point I should be able to re-install the impeller using a new bolt and a lockwasher since the old bolt is shot. (IMG:style_emoticons/default/driving.gif) My Plan B: if I can't remove what is left of the bolt, I plan to rent a U Hauls truck and trailer and pull the car the rest of the way to Muncie, Indiana. I would really appreciate some input on whether my reasoning is sound, if I'm an imbecile, or if I'm SOL thanks in advance, Ross |
Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
That is a pretty serious issue that's located in tough spot, and its put you in a tougher one.
Whether to attempt a field repair depends on some facts missing from your narrative. How's the weather? How much money do you have? If the answer is "not a lot" I suggest cutting your losses and renting a truck. It's against the law, but with a couple of 2x 12's and a come-a-long, you could roll your car into an 18' box truck and be home in a few days. Just be sure you tie it down well. If I recall correctly, lots of important parts inside a 901 transmission turn even when you are coasting in neutral, which makes sense given the transaxle is part of the gearbox. Get some expert advice before putting your car on a tow dolly. Is there a stub of sheared-off bold sticking out on to which someone could spot weld a nut? Has anyone from the shop where you're parked looked at the problem? Using an easy out at that spot entails engine removal IMHO. Maybe they'd let you use their lift? One time my ancient Volvo wouldn't start in a Wendy's parking lot in a very small town in Tn. I was hundreds of miles from my home an had about 24 hours to get to the Miami airport for an overseas flight. I walked two miles to a junkyard to buy a starter. They didn't have one, but one of the guys gave me a ride to another junk yard seven more miles down the road. That yard had a crate-full. We tested them with an old battery until we found the best one and then someone else gave me a ride back to my car. I was on the road an hour later. You just never know. Good luck! |
Lo-Fi Version | Time is now: 24th June 2024 - 07:09 AM |
