rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
SO my teener broke down as I was driving out of South Dakota. I was able to get it towed for free to Mitchell, SD. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
Here is what is broken: The bolt that attaches the Impeller hub to the crankshaft has sheared off inside the crankshaft. This caused the impeller hub to fall off the crankshaft and caused the generator to stop functioning as well as engine cooling to cease. Once the hub fell off the crankshaft, the woodruff key fell out too. Here is my situation: the car is parked at a transmission shop here in Mitchell. I have a full set of sockets and wrnches, as well ass assorted 914 tools, but no jacks or jackstands. I have removed the forward engine tin, as well as the belt, impeller and hub. I have also removed the front half of the impeller shroud. My plan of attack: I want to ask the transmission shop to use an extractor to remove what is left of the bolt with the engine still in the car. if they can remove it I will need to locate a new woodruff key, at which point I should be able to re-install the impeller using a new bolt and a lockwasher since the old bolt is shot. (IMG:style_emoticons/default/driving.gif) My Plan B: if I can't remove what is left of the bolt, I plan to rent a U Hauls truck and trailer and pull the car the rest of the way to Muncie, Indiana. I would really appreciate some input on whether my reasoning is sound, if I'm an imbecile, or if I'm SOL thanks in advance, Ross |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,509 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Guy's renting a U-Haul truck is outragously expensive. I did that when I flew out to LA and bought a 59 MGA. I drove the car about 10 miles after paying for it and heard a rod knocking. The rental place wanted 1K for the truck and another $ 400.00 for the trailer plus gas cost about $ 550.00 to get us home. We could have had a hauler transport the car for less but the biggest part of the deal is it would have cost us $ 600.00 each for plane fare to fly out of LAX on short notice.
I talked the rental guy into letting us take the 17' truck without the trailer. We went to Home Depot and bought two 2x10's, some 2x4's, a cordless screw gun and some ratchet straps. We found a loading dock we could back the MGA up on, Backed the truck up to the dock, placed the planks as ramps and drove into the cube truck. We screwed the 2x4's to the wood floor in the cube truck and used the ratchet straps to hold the car to the 2x4's screwed to the floor like chalk blocks . We placed plastic under the car to catch any oil drips which was the rental guys only real concern. He said you can haul anything you want in the truck but don't get any oil on the floor. People need to haul furniture in there... Anyway, you can do it. The trick is getting it loaded. So, for $ 1400.00 you could pull the engine, rent a truck from home depot to haul the engine to a machine shop and hve them extract the broken bolt, fix the keyway and pay the tranny shop to reinstall the engine. $ 1400.00 could go along way to getting you back on the road. Just MHO. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:56 AM |
