rnellums |
Professional Enthusiast ![]() ![]() ![]() Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains ![]() |
SO my teener broke down as I was driving out of South Dakota. I was able to get it towed for free to Mitchell, SD. (IMG:style_emoticons/default/hissyfit.gif) (IMG:style_emoticons/default/hissyfit.gif)
Here is what is broken: The bolt that attaches the Impeller hub to the crankshaft has sheared off inside the crankshaft. This caused the impeller hub to fall off the crankshaft and caused the generator to stop functioning as well as engine cooling to cease. Once the hub fell off the crankshaft, the woodruff key fell out too. Here is my situation: the car is parked at a transmission shop here in Mitchell. I have a full set of sockets and wrnches, as well ass assorted 914 tools, but no jacks or jackstands. I have removed the forward engine tin, as well as the belt, impeller and hub. I have also removed the front half of the impeller shroud. My plan of attack: I want to ask the transmission shop to use an extractor to remove what is left of the bolt with the engine still in the car. if they can remove it I will need to locate a new woodruff key, at which point I should be able to re-install the impeller using a new bolt and a lockwasher since the old bolt is shot. (IMG:style_emoticons/default/driving.gif) My Plan B: if I can't remove what is left of the bolt, I plan to rent a U Hauls truck and trailer and pull the car the rest of the way to Muncie, Indiana. I would really appreciate some input on whether my reasoning is sound, if I'm an imbecile, or if I'm SOL thanks in advance, Ross |
rnellums |
Rick, I'm just nervous. Everything is running fine. I REALLY don't want to get greedy with success and end up stranded again. There any fan wobble though which is good. I might put the belt on once I get a bit closer.
-Ross |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Rick, I'm just nervous. Everything is running fine. I REALLY don't want to get greedy with success and end up stranded again. There any fan wobble though which is good. I might put the belt on once I get a bit closer. -Ross IMO, and IME, that would be dumb. Play the cards you have in hand, don't draw to disaster. The Cap'n BTW, having the belt too tight would take out the alternator, not the hub and crank. |
Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
Rick, I'm just nervous. Everything is running fine. I REALLY don't want to get greedy with success and end up stranded again. There any fan wobble though which is good. I might put the belt on once I get a bit closer. -Ross IMO, and IME, that would be dumb. Play the cards you have in hand, don't draw to disaster. The Cap'n BTW, having the belt too tight would take out the alternator, not the hub and crank. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 07:48 PM |
