Giving up on ignition switches, Need wiring diagram, Bought a universal starter/ignition switch.. |
Andyrew |
Jun 1 2011, 09:54 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
So my 3rd replacement ignition switch started tweeking out on me. Im tired of this. This is not a stock 914 so I decided to get an aftermarket switch. 10 bucks at Autozone and I have a switch that I doubt i will ever break.
So I pull the wiring which I have become so familar with and see that there are 6 prongs on it. One obviously ground(Black), One obviously power(red, thick), One keyed power (red, thinner), and one obviously starter(yellow).. But then I see 2 other small wires, a white, and a white/brown. Where do these suckers go? There is no accessory switch to the 914 so I doubt anything can go there, Are they the wires that are keyed power or say a relay? How do I wire this on a 4 prong switch??? I would think that the two smaller wires just go on keyed power, but I'd hate to do it and be wrong. Thoughts? Thanks all. |
r_towle |
Jun 2 2011, 10:43 AM
Custom Member Group: Members Posts: 24,683 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
pull the wire from the battery POSOTIVE terminal...remove it from the bundle of other wires so its hanging in the air ALONE.
You could be seeing a dead short in your battery...and that happens when you overcharge a battery... Both the voltage regulators can do this as well as a cheap battery charger...or a super charge 50 amp charger. Then ohm it again. Rich |
Lo-Fi Version | Time is now: 7th January 2025 - 10:33 PM |
