Giving up on ignition switches, Need wiring diagram, Bought a universal starter/ignition switch.. |
Andyrew |
Jun 1 2011, 09:54 PM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
So my 3rd replacement ignition switch started tweeking out on me. Im tired of this. This is not a stock 914 so I decided to get an aftermarket switch. 10 bucks at Autozone and I have a switch that I doubt i will ever break.
So I pull the wiring which I have become so familar with and see that there are 6 prongs on it. One obviously ground(Black), One obviously power(red, thick), One keyed power (red, thinner), and one obviously starter(yellow).. But then I see 2 other small wires, a white, and a white/brown. Where do these suckers go? There is no accessory switch to the 914 so I doubt anything can go there, Are they the wires that are keyed power or say a relay? How do I wire this on a 4 prong switch??? I would think that the two smaller wires just go on keyed power, but I'd hate to do it and be wrong. Thoughts? Thanks all. |
Andyrew |
Jun 2 2011, 12:51 PM
Pulled the positive cable from the battery and separated the wires. It is still continuos with ground..... So, yay.... Hours of toil ahead...
914Mike |
Jun 2 2011, 01:22 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Pulled the positive cable from the battery and separated the wires. It is still continuos with ground..... So, yay.... Hours of toil ahead... Well, yeah, an ohmmeter WILL show a short to ground if ANY load is on the other end of the cable. Do you have a radio with a clock lead connected to permanent power? Or a power amp? Those will look like a short to ground. Do you have a light turned on, or anything else that's on? Do you get a small spark when touching the wire back to the battery terminal? ANYTHING on will look like a short to an ohmmeter. Pull fuses or disconnect the red wires till you are sure that you can see both ends of the same wire hanging in air, THEN if you STILL read a short to ground it will be time to search for the short or replace the wire. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 7th January 2025 - 10:24 PM |
