> Giving up on ignition switches, Need wiring diagram, Bought a universal starter/ignition switch..
Andyrew
post Jun 1 2011, 09:54 PM
Spooling.... Please wait
So my 3rd replacement ignition switch started tweeking out on me. Im tired of this. This is not a stock 914 so I decided to get an aftermarket switch. 10 bucks at Autozone and I have a switch that I doubt i will ever break.
So I pull the wiring which I have become so familar with and see that there are 6 prongs on it. One obviously ground(Black), One obviously power(red, thick), One keyed power (red, thinner), and one obviously starter(yellow).. But then I see 2 other small wires, a white, and a white/brown. Where do these suckers go? There is no accessory switch to the 914 so I doubt anything can go there, Are they the wires that are keyed power or say a relay? How do I wire this on a 4 prong switch??? I would think that the two smaller wires just go on keyed power, but I'd hate to do it and be wrong.
Thoughts?
Thanks all.
Andyrew
post Jun 2 2011, 02:13 PM
914Mike,
I see. That makes sense.
Actually there is nothing that stays on (Radio disconnected completely, no clock, no amplifiers), but im sure one of the light relays has constant on, so that makes sense that there would be continuity there now. And no I actually dont get any sparks when connecting or disconnecting the battery, there is really very little drain.
This short thing just scared me, as I really dont want an electrical fire if I can help it..
I've been doing this on my own, I'll ask my dad for some help tonight, he has way more knowledge and practical experience in wiring than I do..
Andyrew   Giving up on ignition switches, Need wiring diagram   Jun 1 2011, 09:54 PM
tradisrad   go here and find your year and wiring diagram. Gr...   Jun 1 2011, 09:59 PM
Andyrew   I know its usually brown, but its obiously not in ...   Jun 1 2011, 10:05 PM
r_towle   #26 on diagram two, "steering column switch...   Jun 1 2011, 10:38 PM
Andyrew   #26 on diagram two, "steering column switch...   Jun 1 2011, 11:04 PM
kg6dxn   I saw 26 but there are to many wires on that dia...   Jun 1 2011, 11:13 PM
NORD   In the center tunnel there is a wire, don't re...   Jun 1 2011, 10:47 PM
kg6dxn   The black wire is the ignition hot lead. the 2 sma...   Jun 1 2011, 11:00 PM
Andyrew   OK so lets put this down. NEW SWITCH -------- 91...   Jun 1 2011, 11:07 PM
kg6dxn   OK so lets put this down. NEW SWITCH -------- 9...   Jun 1 2011, 11:15 PM
Andyrew   OK so lets put this down. NEW SWITCH -------- ...   Jun 1 2011, 11:18 PM
kg6dxn   So what your saying is im right? :wacko: I j...   Jun 1 2011, 11:23 PM
chrispy   Doesn't one wire go from the switch to the hea...   Jun 1 2011, 11:18 PM
914Mike   So my 3rd replacement ignition switch started twe...   Jun 1 2011, 11:27 PM
Andyrew   MMMMkay... On my testing zone I had the little red...   Jun 1 2011, 11:57 PM
Andyrew   So I disconnected the yellow wire and tried the ke...   Jun 2 2011, 12:01 AM
Andyrew   WTF I disconnect the switch and check it out. Loo...   Jun 2 2011, 12:18 AM
messix   its not hitting "ground" its conducting ...   Jun 2 2011, 12:31 AM
Andyrew   its not hitting "ground" its conducting...   Jun 2 2011, 08:58 AM
jcd914   It sounds like you are trying to connect the after...   Jun 2 2011, 01:21 AM
Andyrew   It sounds like you are trying to connect the afte...   Jun 2 2011, 09:06 AM
Cap'n Krusty   I've probably installed a couple of hundred af...   Jun 2 2011, 10:03 AM
Andyrew   Captn, Yes the aftermarket switch is clearly lab...   Jun 2 2011, 10:34 AM
r_towle   pull the wire from the battery POSOTIVE terminal.....   Jun 2 2011, 10:43 AM
Andyrew   I'll give it a test tonight. Battery is kickin...   Jun 2 2011, 10:54 AM
Cap'n Krusty   I'll give it a test tonight. Battery is kicki...   Jun 2 2011, 11:17 AM
r_towle   cant ohm the red wire while its connected to the b...   Jun 2 2011, 11:03 AM
Andyrew   Well I can say that that relay is LONG gone... Sea...   Jun 2 2011, 11:14 AM
r_towle   reminds me of my plow truck...a dual battery diese...   Jun 2 2011, 11:21 AM
Andyrew   Rick, Cables are under 5 years old. Starter has ...   Jun 2 2011, 11:43 AM
Andyrew   Pulled the positive cable from the battery and sep...   Jun 2 2011, 12:51 PM
914Mike   Pulled the positive cable from the battery and se...   Jun 2 2011, 01:22 PM
Cap'n Krusty   The wires have to be disconnected at BOTH ends for...   Jun 2 2011, 01:24 PM
Andyrew   914Mike, I see. That makes sense. Actually the...   Jun 2 2011, 02:13 PM
Tom   Andyrew, Did you remove the positive battery ...   Jun 2 2011, 04:31 PM
Andyrew   Tom, No, I didnt disconnect the positive battery...   Jun 2 2011, 04:45 PM
Andyrew   For shits and giggles i installed the wiring again...   Jun 2 2011, 07:38 PM
kg6dxn   Test the continuity of your switch (ohm out) Powe...   Jun 2 2011, 08:04 PM
Andyrew   Mike, this is what i tested last night (multiple t...   Jun 2 2011, 08:23 PM
Andyrew   Mike, this is what i tested last night (multiple t...   Jun 2 2011, 08:35 PM
Andyrew   Ooook.. I just tightened the bolts down but left t...   Jun 2 2011, 08:40 PM
kg6dxn   Have you tried to hot wire your car? Just to see i...   Jun 2 2011, 09:00 PM
Andyrew   Defective. The starter terminal worked itself loos...   Jun 2 2011, 09:01 PM
kg6dxn   Damn Chinese parts...   Jun 2 2011, 09:05 PM
Andyrew   Mike, yes i test all functions of the key switch w...   Jun 2 2011, 09:34 PM
Andyrew   Drove to work! :trophy:   Jun 3 2011, 08:32 AM
porscheless   Andy, Glad you got your car sorted; the OEM...   Jun 3 2011, 09:11 AM
NORD   Glad its fixed :headbang: :driving:   Jun 3 2011, 09:00 AM
Andyrew   Joe, where did you get your OEM switch? Porsche?   Jun 3 2011, 09:16 AM
42 User(s) are reading this topic (42 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th January 2025 - 10:43 PM
