VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
tonight I spent about an hour under the car putting the alternator tin back in place and getting the thermostat bolted in.
As I was fishing a string down the hole in the tin for the thermostat wire, on a whim I jiggled the flaps arm. It was stuck. It is stuck. Feeling in with my fingers from the no2 spark plug hole, I can feel that it is open, but it is not moving. Is there a way I can diagnose and fix this without pulling the engine? I have this horrible feeling that if I pull the motor the chances of me driving the Porsche this summer are slim and none. But, on the other hand the carbs are off, fuel is already disconnected - its the right time if I had to do it. And I could find that pesky oil seep in the front of the engine. I know what I SHOULD do. I just really do not want to do it. :-( I have so little time these days to work on the car. Zach |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,117 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
connect the rear end to the ts, use a piece of masking tape across wheel to keep the wire secure in the little metal wheel, pull the loose end up with a piece of small gauge wire.
k |
Lo-Fi Version | Time is now: 29th June 2024 - 08:22 PM |
