rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,984 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
When pressing down on the clutch pedal (clutch disengaged) I hear a high pitch whining/whirring noise. Happens whether the car is moving or not. Noise does not happen with the clutch engaged. (clutch pedal released) Car shifts pretty good, but I think I'm running out of room to adjust the clutch on the clutch cable. (Another issue that probably points to something needing replacement)
I've been searching through posts for an hour and my best guess is throwout bearing. Yes? No? And whatever it is, can I make repair without removing the engine? Thanks! |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
When pressing down on the clutch pedal (clutch disengaged) I hear a high pitch whining/whirring noise. Happens whether the car is moving or not. Noise does not happen with the clutch engaged. (clutch pedal released) Car shifts pretty good, but I think I'm running out of room to adjust the clutch on the clutch cable. (Another issue that probably points to something needing replacement) I've been searching through posts for an hour and my best guess is throwout bearing. Yes? No? And whatever it is, can I make repair without removing the engine? Thanks! Yes, throwout bearing. Leave the clutch cable alone. Live with it till you do the clutch and hope it will not die earlier. You will need a new one any way. |
Lo-Fi Version | Time is now: 24th June 2024 - 06:55 AM |
