lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
I have not found a complete source of accurate information on this topic.
The 914 is listed as having a 108mm four bolt pattern. What measures 108mm? The offset of my empi's are about 100mm. Is this the true specs? I have read else where that offset is a incorrect term. My use of offset is the distance from the inner surface of the wheel to the edge of the wheel rim projected down to the center line. Is this correct? Wheels are measured as 15 x 6.5. How do you measure the with of the rim? Is it from outer (curb surface) to outer or within the bead to bead? If you were to place your ruler on the rims, from what point to what point would you measure? What bolt dia and length and thread patern are standard? Ebay has a set of bolts that are 2 3/8" or 60mm in length and 1 1/2 inch or 36mm thead length. This allows about 50mm engaged inside the rotor hubs. What length should the bolts be inside the rotor hubs to be safely secured? Thanks, L. MCChesney |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
yep, I'm putting rims similar to those on my 914, but I figured out a way to install brushless DC motors to keep the centers spinning when ever I want....when hooked up to the motor controller and G-Tech at the same time I can speedup or reverse the motors to aid in acceleration or brakeing...sorta like reverse intertia.....the hardest thing to figure out is should I make the centers spin at different RPMs while turning around a corner..... (IMG:style_emoticons/default/smoke.gif)
once I get this design down, my next venture will be to make a device to change the air pressure in the tires to maximize the handling corner to corner (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 06:14 AM |
