Idle adjustment screw for D jet, How many turns before idle should change? |
jsaum |
Jun 21 2011, 10:09 AM
Senior Member Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None |
I was helping Matteyp tune his car last night and it's the first time I have worked on a fuel injected engine. We got the dwell set and the engine timed with the light, it's running better but when I tried to adjust the idle speed the adjustment screw didn't seem to affect the idle speed I gave it two full turns in each directions. My questions is how sensitive should this adjustment be?
Jsaum |
Ian Stott |
Jun 21 2011, 11:59 AM
Senior Member Group: Members Posts: 907 Joined: 28-January 08 From: Moncton/Canada Member No.: 8,635 Region Association: Canada |
I adjusted my idle up last weekend, did it when the engine was warm, very little turn on the screw to take idle from 600 to 900/950. Maybe 5 degrees of a turn, very sensitive, but yes all the little vacumn leaks add up, make sure you address those before anything else.
Ian Stott Moncton Canada |
Lo-Fi Version | Time is now: 24th June 2024 - 11:20 PM |
