trfrick |
Long Time Listener First Time Caller ![]() Group: Members Posts: 25 Joined: 28-August 10 From: CA Member No.: 12,113 Region Association: Northern California ![]() |
I need some help - I replace the front rotors, calipers, pad, flex line and m/c. Now when I went for a test drive after several hard stops the front brakes get hot and lock up.
After they cool they release. What should look for? Thanks Tom |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I would start by checking that the brake pedal is letting the master cylinder come all the way back. There needs to be a little clearance between the push rod on the pedal and the piston in the master cylinder. And make sure the brake pedal moves freely, not binding on the bushings.
Jim |
trfrick |
I would start by checking that the brake pedal is letting the master cylinder come all the way back. There needs to be a little clearance between the push rod on the pedal and the piston in the master cylinder. And make sure the brake pedal moves freely, not binding on the bushings. Jim The pedal is adjusted correctly - when the brakes heat up the free play goes away. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:46 AM |
