brake trouble, front brakes lock when hot |
trfrick |
Jun 21 2011, 10:26 PM
Long Time Listener First Time Caller Group: Members Posts: 25 Joined: 28-August 10 From: CA Member No.: 12,113 Region Association: Northern California |
I need some help - I replace the front rotors, calipers, pad, flex line and m/c. Now when I went for a test drive after several hard stops the front brakes get hot and lock up.
After they cool they release. What should look for? Thanks Tom |
Eric_Shea |
Jun 22 2011, 09:43 AM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Where'd ya get the crappy rebuilt calipers? (IMG:style_emoticons/default/hide.gif) (IMG:style_emoticons/default/biggrin.gif)
Tom, can we determine if a piston is sticking or not? Short drive, does one caliper get hotter than the other. Short stop, hands off the wheel, does it pull to one side? It almost sounds like one of your knockback mechanisms' is not working properly causing excessive heat to the system, especially if you have new lines and MC. Do you see any "blueing" on one of the rotors vs. the other? Otherwise I'd double check that pedal free play again as it sounds tailor made to your problem. One other thing to check is the bearing play on your new rotors etc. Double check the spindle nut for tightness and make sure there's no excessive runout causing the rotor to wobble and contact the pads causing heat. Check the pad gap with the car cold... both inside and outside. Can you turn the rotor by hand (when cold) or do you feel a substantial amount of rubbing? If there is substantial rubbing, we may want to look at the bearings as a possible cause. Let's dig in... |
Lo-Fi Version | Time is now: 24th June 2024 - 07:35 AM |
