pete |
Member ![]() ![]() Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States ![]() |
I need to purchase a radiator for my SBC conversion and am in need of some suggestions/part numbers. JEGS? Also, will need a over flow canister and hoses.
BRAVE_HELIOS |
"Knowledge speaks, wisdom listens" ![]() ![]() Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest ![]() |
In my setup I went with a Giffin radiator, model 125241-H... no radiator cap. The dimensions are 16"x 27.5" x 3". It's installed to float in its mounts versus mounted rigidly.
I also used one of the most powerful fans ever put in a production vehicle (Google it)... an early to mid-ninties Ford Taurus/Sable fan. I think the only one more powerful (and larger) is out of a Mark VIII. Local junk yard for $20.00. Note that fan shroud covers about 90% of radiator surface... perfect! Then of course, you need to get the controller, mine is an adjustable unit. So far so good!! (IMG:style_emoticons/default/biggrin.gif) ![]() ![]() ![]() |
pete |
In my setup I went with a Giffin radiator, model 125241-H... no radiator cap. The dimensions are 16"x 27.5" x 3". It's installed to float in its mounts versus mounted rigidly. I also used one of the most powerful fans ever put in a production vehicle (Google it)... an early to mid-ninties Ford Taurus/Sable fan. I think the only one more powerful (and larger) is out of a Mark VIII. Local junk yard for $20.00. Note that fan shroud covers about 90% of radiator surface... perfect! Then of course, you need to get the controller, mine is an adjustable unit. So far so good!! (IMG:style_emoticons/default/biggrin.gif) ![]() ![]() ![]() This is a nice clean set up and I would be inclined to go with 1 fan rather then two as long as it keeps things cool. So you have a remote filler for the radiator? Also, those look like 2-3" hoses going through the floor. Are you running hoses that large of a diameter under the car? |
Lo-Fi Version | Time is now: 12th April 2025 - 02:46 AM |
