> I need a radiator for my SBC conversion, Ideas? Part numbers?
pete
post Jun 21 2011, 10:52 AM
I need to purchase a radiator for my SBC conversion and am in need of some suggestions/part numbers. JEGS? Also, will need a over flow canister and hoses.
Andyrew
post Jun 22 2011, 01:25 PM
Spooling.... Please wait
Pete,
You wire them yourself, Typically on a switch or on a controller that is connected with the water temp sender (aka it activates at a certain temp). For getting around town you could just put it on a toggle switch and turn it on when it reaches temp (thats what I do).
Also he is probably running the standard size hoses under the car, the big hoses at the radiator are because they are preformed to be able to make the angles required in the confined space, then you would run a reducer.
The fill for the radiator will be in the engine compartment, This is because the radiator is lower than the engine and the fill needs to be the highest point to allow the air not to get trapped in the system. Best to run something inline that has a long neck or something so that you have room for air. See the modern radiator fills, they have a big box that has a level on it, water flows through that box in line and because there is a bunch of extra water in it it never gets air in the lines and it constantly is purging air.
pete   I need a radiator for my SBC conversion   Jun 21 2011, 10:52 AM
Andyrew   Budget? You could build a radiator system from ...   Jun 21 2011, 11:02 AM
pete   Budget? You could build a radiator system from ...   Jun 21 2011, 12:46 PM
messix   from s10 v8 conversions they're using a stock ...   Jun 21 2011, 12:52 PM
andys   The only real semi-bolt-in system that I know of i...   Jun 21 2011, 01:13 PM
BIGKAT_83   My favorite C&R Radiator comes in a 14x27.5...   Jun 21 2011, 01:53 PM
joefri187   I need to purchase a radiator for my SBC conversi...   Jun 21 2011, 02:00 PM
pete   [quote name='pete' post='1497484' date='Jun 21 20...   Jun 21 2011, 02:20 PM
Andyrew   Joe, Thats a nice looking setup! Nice shee...   Jun 21 2011, 02:10 PM
Andyrew   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 02:15 PM
BIGKAT_83   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 04:19 PM
Andyrew   Bob, Pick and pull in my area would charge ...   Jun 21 2011, 11:01 PM
joefri187   Here are a couple more pics... The radiator is fl...   Jun 21 2011, 02:55 PM
pete   Here are a couple more pics... The radiator is f...   Jun 22 2011, 01:18 PM
matthepcat   Fluidyne built one custom to my specs using the Pa...   Jun 21 2011, 03:25 PM
BRAVE_HELIOS   In my setup I went with a Giffin radiator, model 1...   Jun 21 2011, 05:52 PM
pete   In my setup I went with a Giffin radiator, model ...   Jun 22 2011, 01:02 PM
BRAVE_HELIOS   In my setup I went with a Giffin radiator, model 1...   Jun 23 2011, 05:36 PM
BRAVE_HELIOS   Hey all, I've had my setup in place for a whi...   Sep 10 2014, 02:41 PM
jcd914   It's all relative. When I needed a pair of fa...   Jun 22 2011, 10:41 AM
Andyrew   Pete, You wire them yourself, Typically on a swi...   Jun 22 2011, 01:25 PM
joefri187   Andrew nailed it.... I used a Derale adjustable f...   Jun 22 2011, 02:05 PM
andys   Andrew nailed it.... I used a Derale adjustable ...   Jun 22 2011, 02:16 PM
Andyrew   Good thing about those copper tubes is you can eas...   Jun 22 2011, 02:48 PM
joefri187   Good thing about those copper tubes is you can ea...   Jun 22 2011, 04:10 PM
drive-ability   Griffin double pass 9D-10682-01   Jun 22 2011, 10:11 PM
pete   Griffin double pass 9D-10682-01 Hi, I tried fin...   Jun 23 2011, 08:57 AM
drive-ability   Griffin double pass 9D-10682-01 Hi, I tried fi...   Jun 23 2011, 09:05 PM
pete   Griffin double pass 9D-10682-01 That's an a...   Jun 23 2011, 09:56 AM
andys   I used the AFCO 80133N which is available from Sum...   Jun 23 2011, 10:00 AM
ChristopherB   Does this thread, and these different set ups appl...   Mar 15 2013, 08:08 AM
bulitt   If you purchase a short enough radiator you can in...   Mar 15 2013, 08:23 AM
boxstr   It seems that the radiator has always been the Ach...   Mar 15 2013, 09:24 AM
pete   I can't believe I still haven't procured t...   Mar 15 2013, 09:30 AM
slothness   Don't skimp on cooling, re-read your old threa...   Mar 15 2013, 09:52 AM
ChristopherB   Does the set up differ depending on the engine use...   Mar 15 2013, 02:49 PM
kg6dxn   As a rule of thumb: You should use a radiator with...   Mar 15 2013, 05:12 PM
76-914   I would think it's too small plus square tubin...   Sep 10 2014, 04:00 PM
BRAVE_HELIOS   Did some research this evening. Found that mountin...   Sep 10 2014, 08:01 PM
Chris H.   Yeah that square tubing size sounds very small for...   Sep 10 2014, 08:37 PM
Mike Bellis   Temp sensor should be on the engine to know how ho...   Sep 10 2014, 10:13 PM
speed metal army   Don't forget flow! The rad needs to be big...   Sep 10 2014, 10:30 PM
Mike Bellis   Don't forget flow! The rad needs to be bi...   Sep 10 2014, 11:20 PM
CptTripps   I used an aluminium double-pass VW Scirocco radiat...   Sep 11 2014, 09:51 AM
mikesmith   Not certain about Mike's setup, but I have the...   Sep 12 2014, 02:25 PM
- Lo-Fi Version Time is now: 12th April 2025 - 02:31 AM
