Krank |
Member ![]() ![]() Group: Members Posts: 140 Joined: 11-October 09 From: Winnipeg, MB Member No.: 10,922 Region Association: Canada ![]() |
I have been thinking about doing the beemer front disk brake upgrade. The only thing that bothers me is the loss of the parking /(cough, cough) emergency brake. I had an idea to look for a motorcycle front disk brake rotor mounted to the axleshaft with a cable operated brake assembly mounted to the tranny (I think there are three useable bolts on the RH side). Anyone play with this idea before?
nsr-jamie |
914 guy in Japan ![]() ![]() ![]() Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None ![]() |
Might as well update or upgrade your whole front end and front brakes with a 911 suspension that most of us do. Its not that big of a job and if you can get the parts for a good price is a nice upgrade plus allows the use of 5 bolt Porsche wheels and adds some value to your car as well...not to mention poser points too
I got mine for very cheap from a 911T car that was rear ended and it made a nice improvement plus you get the slightly heavier torsion bars as well. I upgraded to new Koni shocks, new rotors later on, braided lines and new pads along with a 19mm master and its very nice....also added new BF goodrich tires and that was even better...eventually when I fix some other problems and make more progress I want to upgrade to Eric Shea's 3 inch alloy brake upgrade and some cross drilled rotors when funds allow. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:06 AM |
