biker bob |
Member ![]() ![]() Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region ![]() |
Started the car (72 2.0 L) this morning to go for gas. Alternator light stayed on for about 15 seconds after engine started then went out. Restarted the engine after getting gas and the light went out. Returned home no issues. Restarted engine after about 30 minutes. The alternator light came on and would not go out. Drove around the block and light remained on. Checked charging at battery NO charging.
2000 miles on new belt, new Bosche alternator,and new Bosche voltage regulator. Alternator wires properly plugged into the relay board. Belt properly adjusted. Transmission ground strap clean and tight. Help needed. |
76-914 |
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,516 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California ![]() ![]() |
Some great info here. Is there a way to bench test the alt at home? I tried several FLAPS a few years ago and none were able to bench check our externally regulated alt's. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 22nd June 2024 - 09:06 PM |
