biker bob |
Member ![]() ![]() Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region ![]() |
Started the car (72 2.0 L) this morning to go for gas. Alternator light stayed on for about 15 seconds after engine started then went out. Restarted the engine after getting gas and the light went out. Returned home no issues. Restarted engine after about 30 minutes. The alternator light came on and would not go out. Drove around the block and light remained on. Checked charging at battery NO charging.
2000 miles on new belt, new Bosche alternator,and new Bosche voltage regulator. Alternator wires properly plugged into the relay board. Belt properly adjusted. Transmission ground strap clean and tight. Help needed. |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Brake light: Make sure the handbrake handle is down, pressing the button in the floor. Also try to reset the switch in the master cylinder; there should be a button covered by a rubber nipple. Press the button to reset the switch.
--DD |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:41 PM |
