flash914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California ![]() |
I'm new to 914's and 914 world but have bein in the auto repair world all of my life. Now the problem I have is I am putting back together a 1970 914 that has sat on a hill top for the last 8 years. With the help of my cousin ( a donated 1.8 long block ) I had it running but very poorly. I traced it back to a busted MPS and after much research desided on a MEGA SQUIRT II V3.0 with a firm ware 2.9050. I've built my board. put it in the box and started to build the harness. I'm not using the ingition side of the system (yet) but may in the future. I done a lot of reading on the mega squirt and so far every thing look good but am looking for fuel mapping tables. I know if you have them you put a lot of work in them. but I'm edgey to get this thing on the road and any help would mean a lot. (IMG:style_emoticons/default/headbang.gif) When I get it running I hope to post mine and maybe start a tradeing page Thanks
JamesM |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region ![]() |
Maps are going to vary between cars depending on how the MS was setup. Changes in injectors, intake, exhaust, resistor packs, PWM settings, and req fuel setup, will cause a map that works on one car to run like complete crap on another.
Someone else map should be enough to get your car started provided both you and them had set their req. fuel variable to properly match the injectors being used, it will most likely need tuning after you get it started though. If you provide a very specific description of your setup someone might have something close. -James I'm new to 914's and 914 world but have bein in the auto repair world all of my life. Now the problem I have is I am putting back together a 1970 914 that has sat on a hill top for the last 8 years. With the help of my cousin ( a donated 1.8 long block ) I had it running but very poorly. I traced it back to a busted MPS and after much research desided on a MEGA SQUIRT II V3.0 with a firm ware 2.9050. I've built my board. put it in the box and started to build the harness. I'm not using the ingition side of the system (yet) but may in the future. I done a lot of reading on the mega squirt and so far every thing look good but am looking for fuel mapping tables. I know if you have them you put a lot of work in them. but I'm edgey to get this thing on the road and any help would mean a lot. (IMG:style_emoticons/default/headbang.gif) When I get it running I hope to post mine and maybe start a tradeing page Thanks |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:37 PM |
