LED Conversion - snafus? |
mcbrems |
Jun 23 2011, 01:33 PM
Ferdinand's first was Electric! Group: Members Posts: 46 Joined: 26-April 10 From: North San Diego County, CA Member No.: 11,660 Region Association: Southern California |
Hey All,
I swapped all of my bulbs for LEDs from Autolumination and/or superbrightleds, and have encountered some unexpected issues. Replacing the turn signal flasher was a known. I tried TimK's hack on the CF13 GL-02 flasher, and when installed and engaged, it just sat there, although the hazard flashers worked fine (it seems to work on the same relay). I noticed this aftermarket "LED" compatible relay design leaves out the "C" ground pin, so I have a different one on order from Autolumination that has it. When I raise my headlights, the tachometer dials up to 3-4K and then returns to rest. My dash instrument lights have also been replaced with tiny LEDs to match the originals, but they only flash once briefly when the light switch is pulled. My blue high beam indicator is lit when the parking lights are on, and my license plate lights never come on. I picked up a 1974 color wiring diagram from Prospero's Garage ( http://stores.ebay.com/Prosperos-Wiring-Di...sid=p4340.l2563 ) and noticed that many of the wires that connect to the computer are tied together. I cut that part of the harness off and tied off all of those wires individually (see image). I'm wondering if I need to reconnect some of those wires to preserve the original circuit path. <http://914electric.files.wordpress.com/2011/06/elect_danglies.jpg> http://914electric.files.wordpress.com/201...ct_danglies.jpg Does anybody have similar experiences? Also, is there a good source for the factory color wiring diagram (Prospero's diagrams do not give terminal designations for any switches - i.e. 56A, 56, C, 32, etc.). Much thanks for any help. (I was informed by Mikey at 914Rubber that there is another markb, so from now on I will be:) MCBrems |
RickS |
Jun 23 2011, 10:40 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
I only replaced the gauge illumination lights with LEDs and have no issues. What's the purpose in replacing turn signal, hand brake bulbs, etc? Perhaps I am missing something... which is very likely.
mcbrems |
Jun 24 2011, 10:37 AM
I only replaced the gauge illumination lights with LEDs and have no issues. What's the purpose in replacing turn signal, hand brake bulbs, etc? Perhaps I am missing something... which is very likely. Well, this is an EV conversion, and I want to minimize my power consumption as much as possible. I think the issues I am seeing with the gauge illumination may have something to do with the dimmer on the parking/headlight switch. I was considering swapping all the bulbs back to incandescent for troubleshooting purposes. Does the dimmer work for your gauge lighting? MCBrems |
914Mike |
Jun 25 2011, 12:07 AM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Well, this is an EV conversion, and I want to minimize my power consumption as much as possible. MCBrems If you calculate the added range from replacing every bulb in the car with LED's you will find that you might actually gain on the order of 100's of feet of range over the incandescent bulbs, certainly not miles. I converted to LEDs for the look (added brightness IF you get the right bulbs) and the bragging rights, not for added range. Headlights are the major draw, converting to HID ($$$) is currently the only lower-current alternative that are bright enough, IMO. |
Lo-Fi Version | Time is now: 27th September 2024 - 09:38 AM |
