superdad88 |
Newbie ![]() Group: Members Posts: 23 Joined: 24-June 11 From: omaha,ne Member No.: 13,238 Region Association: Upper MidWest ![]() |
![]() ![]() ![]() ![]() ![]() Ok here are the pics of the car that I am going to buy. I worked on getting it running and I believe I think I know what's wrong with it. I wasnt getting any spark to the spark plugs. So I traced it all the way back to the MSD. I believe the MSD is bad but wanted to ask you guys for sure before I go and spend 300 bucks. There is a gold box to the right of the MSD, not sure what this is. I did check the transformer and I am getting voltage from there. I checked the MSD as per their website and from what I can tell its not providing spark. But what is the gold box? Wanted to make sure it might be something simple and I am missing it before I spent the 300 bucks. |
superdad88 |
Would you mind restating that?: The MSD can be tested independently. Power on, intermittently ground the 'points wire.' You should make sparks. The points replacement can also be tested separately with a meter. That's how I checked to see if the MSD was bad. I didnt get any spark. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Would you mind restating that?: The MSD can be tested independently. Power on, intermittently ground the 'points wire.' You should make sparks. The points replacement can also be tested separately with a meter. That's how I checked to see if the MSD was bad. I didnt get any spark. Where did you check for spark? Did you index the engine so the disty rotor is pointing to a spark plug? For my 2 cents, go to a Pertronix electronic points replacement and standard blue Bosch coil. This is relatively simple and works. Some say they fail if the ignition is on and the engine not running so I just avoid this situation. |
Lo-Fi Version | Time is now: 24th June 2024 - 05:34 AM |
