Valve adjustment weirdness, valve adjustment |
Java2570 |
Jun 27 2011, 09:18 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Ok, I'm a newbie with a 1974 914 2.0L. I am replacing my heat exchangers and exhaust this week and while I have them off, I figure I'd adjust the valves while
I've got extra room to do so. So.... I spent time finding TDC notch on my flywheel and scribed a mark corresponding on the bottom viewing window of the trans. I also have a red paint mark that was made on the fan that lines up with this as well. When I go to adjust valves on #1, they are very tight and can't even get a feeler gauge into it to adjust. Then when I try to loosen the screw, it is making no difference in the looseness of the adjustment. What is happening here? Am I making some stupid mistake or is there something wacky going on? I've adjusted valves before on Karmann Ghias so I know how to do the adjustment basically. Also, the nuts are not 13 mm, they are 14 mm on this engine. I know the engine is from a 1975 car but I'm not sure if the rocker arms were replaced or not......confused. Am I doing something wrong here? Thanks! |
TheCabinetmaker |
Jun 27 2011, 09:48 AM
I drive my car everyday Group: Members Posts: 8,309 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
When the notch on the flywheel can be felt through the top hole where the trans and block mate up, pop the distributor cap and and see if the rotor points toward the small notch in the top ot the distributor housing. Its about the 10:00 position viewing the diz from the rear. If it points 180 from that notch, turn the crank one more revolution. You can remove the #1 plug and insert a plastic straw (not a chopstick) (inside joke) to verify the piston is at TDC.
Lo-Fi Version | Time is now: 24th September 2024 - 12:53 PM |
