Java2570 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest ![]() |
Ok, I'm a newbie with a 1974 914 2.0L. I am replacing my heat exchangers and exhaust this week and while I have them off, I figure I'd adjust the valves while
I've got extra room to do so. So.... I spent time finding TDC notch on my flywheel and scribed a mark corresponding on the bottom viewing window of the trans. I also have a red paint mark that was made on the fan that lines up with this as well. When I go to adjust valves on #1, they are very tight and can't even get a feeler gauge into it to adjust. Then when I try to loosen the screw, it is making no difference in the looseness of the adjustment. What is happening here? Am I making some stupid mistake or is there something wacky going on? I've adjusted valves before on Karmann Ghias so I know how to do the adjustment basically. Also, the nuts are not 13 mm, they are 14 mm on this engine. I know the engine is from a 1975 car but I'm not sure if the rocker arms were replaced or not......confused. Am I doing something wrong here? Thanks! |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Most of the time, TDC is marked white and the 27 degree BTDC is marked red.
Opposite valve method ... you don't need to see the other side of the engine. If the valve is in the down (open position), its' partner on the other side is fully closed and on the base circle (heel) of the cam. No guesswork period as you don't have to find TDC or know what cylinder you are on. Sorry Zach ... didn't read your post entirely. |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:18 PM |
