Prospectfarms |
Member ![]() ![]() Group: Members Posts: 495 Joined: 7-March 11 From: Louisville, KY Member No.: 12,801 Region Association: Upper MidWest ![]() |
My AAR was dead. Not only that but it shorted out and ruinined my ignition harness. The hot lead coming from underneath the unit lost its insulation. The valve and the heating element were both inoperable. Here's how I fixed it.
The AAR is a can holding a spring. The spring is really a bi-metal strip curled to resemble a watch spring. It serves as a thermostat. A valve on top of the can is regulated by that spring. The valve admits "auxillary air" to the manifold. I opened the can by first cutting slots across the top of the "lip." I used a pneumatic cut-off saw. You could use anything that cuts metal. As you can see I was not very careful and it turned out alright. Opening the can separates it from the valve and exposes the spring. Tow screws are attached to the spring. The one on the side is the adjustment. It is self-explanatory given that it controls where the opening of the valve is in relation to the spring. The other screw retains the spring to the valve shaft. It provides a handy place to put a small screw driver so you can turn the valve back and forth. I loaded the valve with penetrating oil. I had to remove the spring to really work it until the valve turned smoothly. The spring comes on and off easily. There is a tiny cotter pin holding the shaft in place, but you don't have to remove it. ![]() ![]() ![]() ![]() ![]() Excuse the duplicate photo. Next... Attached image(s) ![]() |
Prospectfarms |
II
Next I addressed the heating element in a ceramic fixture riveted to the bottom of the can. Drill the rivet out, as wall as the two terminal rivets for the heating element. Take it all out. I put a couple of holes in the side of the can to run a positive and negative lead. I didn't want any wires underneath the can to get pinched when you screw it to the engine. I had some resistors in a shoebox in my garage. I eyeballed a couple and soldered them together. Long lead is positive. If you want to precisely duplicate the heating element -- good luck. Dave Darling recommends 120 ohms. I can't argue with him. The resistors in the bottom of the ceramic cup are a tight fit. I grounded them through the bottom hole and applied a dollop of solder to the negative lead from the outside. The positive wire is routed out through one of the holes in the side. No problem, but it took to long to adjust the resistors so they wouldn't interfere with the spring when I put everything back together. I decided to try another way.... ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 12:11 AM |
