Newbie Question of the Day: Conversions and Flywheels |
RiqueMar |
Jun 30 2011, 06:19 PM
Enrique Allen Mar Group: Members Posts: 2,176 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
Ok, did a search but just making sure. When doing a /6 conversion (mine is a 77' 'S' Engine) and sticking with the 901 transmission, I need to change the Flywheel, correct?
I'm all ready to go, but I believe I have the wrong flywheel (mine has the ring gear separate). |
pcar916 |
Jul 1 2011, 08:10 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Yes, because regardless, you'll want to use a 225mm clutch package. I've used the same 914 style clutch (push-type) for both the 2.7L and 3.6L engines.
But with both I used Sachs "Sport" parts (bigger springs in the pressure plate). For some reason I didn't write down the part numbers. Somebody else know them? The 3.6L uses the same clutch and pressure plate, but a different (6.75lb) flywheel with a speed sensor ring for the DME. Good luck! |
Lo-Fi Version | Time is now: 26th September 2024 - 12:07 PM |
