need to fix a stripped CHT hole, I only have myself to blame |
brant |
Jul 10 2011, 11:01 PM
914 Wizard Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
about 3 years back I tore a motor down to rebuild my rebuild.... (long story)
anyways, I only have myself to blame today I started bolting on the externals and tin found out that the CHT hole is stripped. motor is assembled and I really don't want to pull the head at this point for welding...... how do folks feel about a time sert or a heli coil in this application. I think I happen to have a heli-coil in the right size... but if I had to buy a time-sert to make it conduct the heat into the sensor I would do it. what do folk think? John, how would you tackle this repair? thanks in advance everyone. brant |
AvalonFal |
Jul 11 2011, 04:45 PM
Member Group: Members Posts: 483 Joined: 3-July 05 From: Southern New Jersey Coast Member No.: 4,367 Region Association: MidAtlantic Region |
Used a TimeSert to do the same thing. I had to drill out the old broken CHT first. The CHT hole has a bottom so measure and use the tape trick for the drill bit, if drilling, and on the tap. TAKE YOUR TIME and keep the tap perpendicular to the hole. Here's a pic.
Paul |
Lo-Fi Version | Time is now: 26th June 2024 - 04:52 AM |
