Oil viscosity and engine heating |
Bartlett 914 |
Jul 9 2011, 09:47 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I am driving from Chicago to Reno today. I did 22 hours in the seat and I have 700 miles to go!
I am having some cooling issues. I feel I am running hotter than I used to. I did have a lean running condition and I think I am out of the woods on this one. I installed an AFM meter. I had to boost the fuel pressure to get to 13.9 to 14.4. The other thing I did was I used Brad Penn 20 W 50 oil. I was running Royal Purple 10 w 40. I used the Brad Penn because it was available and this oil is supposed to be the oil to use (but maybe not the viscosity) Could this be causing a heating problem? I think an external oil cooler may be in my future. FWIW, I was near the red in the early morning cool hours pushing 70. Once I got to west Nebraska and Wyoming, the heat became a real issue. I plan on Being in Reno for more than a week, anyone want to connect up. drop a pm. I would love to hear form anyone here |
r_towle |
Jul 12 2011, 02:39 PM
Custom Member Group: Members Posts: 24,638 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
how is your timing? might be off after a long run and may contribute to your hot running conditions.
Consider also, remove the plastic tray under the engine lid...might give you back a few degrees. I drove with my decklid open one hot summer day coming back from PA through NYC traffic....that did the trick....just a bit more air was all it needed. RIch |
Bartlett 914 |
Jul 12 2011, 07:21 PM
how is your timing? might be off after a long run and may contribute to your hot running conditions. Consider also, remove the plastic tray under the engine lid...might give you back a few degrees. I drove with my decklid open one hot summer day coming back from PA through NYC traffic....that did the trick....just a bit more air was all it needed. RIch I took out the rain tray. This made a big enough difference to get me here. I will re check my timing. I got some 10 w 30 Royal Purple. I will change it out tomorrow. I thought the altitude would make me rich also. Speaking with my customer who is a big bike fan, he said the altitude here also made him lean and had to richen up. He also said when he would go to Oregon he needed to lean out. His thoughts were the humidity was the difference. All in all, I still have time. I will be here another week. I want to try one thing at a time. In the morning I will disconnect the air temperature sensor. In the evening I will change the oil. Still need a vacuum gauge. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:27 PM |
