> Oil viscosity and engine heating
Bartlett 914
post Jul 9 2011, 09:47 PM
I am driving from Chicago to Reno today. I did 22 hours in the seat and I have 700 miles to go!
I am having some cooling issues. I feel I am running hotter than I used to. I did have a lean running condition and I think I am out of the woods on this one. I installed an AFM meter. I had to boost the fuel pressure to get to 13.9 to 14.4.
The other thing I did was I used Brad Penn 20 W 50 oil. I was running Royal Purple 10 w 40. I used the Brad Penn because it was available and this oil is supposed to be the oil to use (but maybe not the viscosity) Could this be causing a heating problem? I think an external oil cooler may be in my future. FWIW, I was near the red in the early morning cool hours pushing 70. Once I got to west Nebraska and Wyoming, the heat became a real issue.
I plan on Being in Reno for more than a week, anyone want to connect up. drop a pm. I would love to hear form anyone here
post Jul 13 2011, 08:19 AM
Good luck with your temp concerns.. and congrats on your short trip (IMG:style_emoticons/default/smile.gif)
Bartlett 914   Oil viscosity and engine heating   Jul 9 2011, 09:47 PM
underthetire   I think your a little on the lean side still. I sh...   Jul 9 2011, 09:55 PM
Bartlett 914   I think your a little on the lean side still. I s...   Jul 9 2011, 10:04 PM
914Mels   I think your a little on the lean side still. I ...   Jul 9 2011, 10:29 PM
Bartlett 914   [quote name='Bartlett 914' post='1506903' date='J...   Jul 9 2011, 10:38 PM
underthetire   You really got problems if your fuel pressure is m...   Jul 10 2011, 12:30 PM
914Mels   You really got problems if your fuel pressure is ...   Jul 10 2011, 01:23 PM
Joe Owensby   I would love to see if the temps came back down a ...   Jul 10 2011, 03:50 PM
Jake Raby   Sounds lean... Brad Penn dies typically run hotter...   Jul 10 2011, 04:10 PM
Bleyseng   Does the engine ping at all? what is the engine ti...   Jul 10 2011, 04:14 PM
Bartlett 914   Hi All. Well I made here. Damn is it hot here...   Jul 10 2011, 09:01 PM
Don M   check with EBS in Sparks.   Jul 11 2011, 07:13 AM
brant   royal purple oil is a synthetic and does have good...   Jul 11 2011, 11:51 AM
Bartlett 914   royal purple oil is a synthetic and does have goo...   Jul 11 2011, 07:43 PM
Dave_Darling   Who (or What)is EBS in Sparks? Engine Builder...   Jul 12 2011, 11:17 AM
ArtechnikA   ... Sparks, NV. Evidently a suburb of Reno. ...   Jul 12 2011, 12:11 PM
Vacca Rabite   Going up in elevation would make you richer. You w...   Jul 12 2011, 03:53 AM
rick 918-S   I was thinking Vaccum leak. Could be heat related ...   Jul 12 2011, 07:06 AM
r_towle   how is your timing? might be off after a long run ...   Jul 12 2011, 02:39 PM
Bartlett 914   how is your timing? might be off after a long run...   Jul 12 2011, 07:21 PM
Cap'n Krusty   how is your timing? might be off after a long ru...   Jul 12 2011, 08:12 PM
Bartlett 914   [quote name='Bartlett 914' post='1508389' date='J...   Jul 12 2011, 09:09 PM
messix   do you have stock heat exchangers? are the heat du...   Jul 12 2011, 07:46 PM
Bartlett 914   do you have stock heat exchangers? are the heat d...   Jul 12 2011, 07:52 PM
Jake Raby   Cap'n I am glad to see you post that.. Perhaps...   Jul 12 2011, 08:31 PM
r_towle   I agree, I run 20w50 in the summer and 10w 30 in t...   Jul 12 2011, 08:39 PM
r_towle   get 20w50 oil... The temp gauge you are reading is...   Jul 12 2011, 09:12 PM
Bartlett 914   get 20w50 oil... The temp gauge you are reading i...   Jul 12 2011, 09:16 PM
r_towle   oh, I thought you said you had 10w30 in there now....   Jul 12 2011, 09:28 PM
Bleyseng   Sounds like changing the dizzy is your problem. Re...   Jul 13 2011, 08:00 AM
396   Good luck with your temp concerns.. and congrats o...   Jul 13 2011, 08:19 AM
Bartlett 914   Thanks for all the replies. The input was helpful....   Jul 26 2011, 11:47 AM
Jake Raby   Get a real gauge with incremental values. No one k...   Jul 26 2011, 06:11 PM
- Lo-Fi Version Time is now: 31st October 2024 - 07:27 PM
