Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
I have dual Delorto 40mm DRLAs on my 2.0 engine with euro P/C's and stock cam and I am wondering of those running carbs, what venturi sizes you are using. I believe the carbs came set up with 34mm venturies. I may have seen a post relating to use a smaller venturi for better driveability. What venturi size do you run and what is your jet set up? If I remember correctly, I may have 140 mains and 60 idle jets. Thanks in advance Dave Hall
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
34s are perfect for your application. A dell loves a larger vent than a weber.
The combo of jets and vent is perfect for most applications with a Dell if you have a 180 air corrector. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:50 AM |
