andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG.
Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Attached image(s) ![]() |
914Mels |
Member ![]() ![]() Group: Members Posts: 357 Joined: 20-June 11 From: Santee Member No.: 13,221 Region Association: Southern California ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG. Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Very clean looking. Is that a radiator up front or do you just have a really big A/C condenser? |
andys |
Lo-Fi Version | Time is now: 26th June 2024 - 05:39 AM |
