andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
Painted the car finally - I took two days to do the sealer, base, and clear (It took me nearly 5 hours just to mask and skirt, as I put the car on jack stands). Color is GT Silber. Used (very) $$$ PPG.
Scottyb, you were right about the amount of base. I used just under than 2 quarts for three coats (the cabin, engine bay, and inside both trunks were already done). PPG does not recommend reducing the clear, but every painter I talked to said to reduce it. Guy that owned the booth said to reduce the hell out of it, and as it turns out, that worked out really well. I started the initial color sanding with 1000 grit to knock it down before the clear got too hard. Managed to get about 3 1/2 corners of the car complete; then on to the doors, trunks, lid, and targa. I'll do final sanding and buffing after assembly (cause you never know what oops might happen!). Andys Attached image(s) ![]() |
jim dorociak |
Member ![]() ![]() Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California ![]() ![]() |
Andys - are not the guys running 7 x 16" fuchs still using a spacer to fill the wheel well? So the width is really not the issue as much as the offset of the wheel - this is a statement and a question. When I build for widebody 911 cars - turbo cars have built in spacer into the front hub that moves the wheel out approx 21mm. I build 8.5" front wheels using 6.5 inner and 1.75" outer. I could build with a 2.25 and a 5.5 and make an 8" but everyone seems to want the largest wheel front and rear they can get. I have a front wheel here that is 5.5 inner rim and 2.75" outer rim making a 8.5" wheel this offset if very close to the 4 7/8 of a fuchs wheel. I have been saving parts for a set of wheels for my not yet started 914 project car. Jim jdorociak@gmail.com
andys |
Andys - are not the guys running 7 x 16" fuchs still using a spacer to fill the wheel well? So the width is really not the issue as much as the offset of the wheel - this is a statement and a question. When I build for widebody 911 cars - turbo cars have built in spacer into the front hub that moves the wheel out approx 21mm. I build 8.5" front wheels using 6.5 inner and 1.75" outer. I could build with a 2.25 and a 5.5 and make an 8" but everyone seems to want the largest wheel front and rear they can get. I have a front wheel here that is 5.5 inner rim and 2.75" outer rim making a 8.5" wheel this offset if very close to the 4 7/8 of a fuchs wheel. I have been saving parts for a set of wheels for my not yet started 914 project car. Jim jdorociak@gmail.com Jim, I'm having a little trouble following you're post. My wheels are stock 993; 7.5" front, and 9.5" rear (IIRC). I don't remember the offsets, but I calculated my spacer dimensions for the rear based on wheel well fit (since there's barely enough room for the 255-17"s). On the front, I needed 1 5/8" spacers to put the wheel in the correct place (scrub radius wise), but as I mentioned earlier, I went with 2". In an earlier post, I think you mentioned building a set of custom wheels. Though I intend on keeping what I have for now, what kind of custom wheels do you offer? I'm not a fan of large diameter wheels on a 914; 17" to me are already a bit large, and I don't personally like that Chip Foose wheel look on 70's vintage cars. 15" just look right to me (IMHO). Andys |
Lo-Fi Version | Time is now: 26th June 2024 - 05:24 AM |
