> SS HE wont fit on head. Please help !, PO had replaced head stud with bigger one
913B
post Jul 22 2011, 08:15 PM
It had to the be studs where the HE bend is. The replacement bolt and screw is just too close to the heat exchnager pipe. It was ok when the previouse owner just had stock HE. But the SS HE are bigger and I cannot get a socket around the replacement nut.
Whats my options ? Hope and try to locate smaller nut at local Home Depot or McMaster
I even thought about taking the HE to someone to heat it up and make a slight indention in it to give me more room.
Am I screwed. Any thoughts.
Thanks so much.
Ted
913B
post Jul 22 2011, 09:18 PM
QUOTE(HAM Inc @ Jul 22 2011, 07:26 PM) *
Get some 911 exhaust nuts. They are internal wrenching (meaning they use an allen wrench). A long reach 8mm allen socket will make easy work of that.
http://www.pelicanparts.com/catalog/shopca..._pg4.htm#item21
Here's the part #999-085-001-02-M260
Hmm. I like that idea. Unfortunately the PO changed the stud. I wonder if I can get the right pitch and size for my bolt from Mcmaster.
Thank you for tip !
porsche913b_sp   SS HE wont fit on head. Please help !   Jul 22 2011, 08:15 PM
geniusanthony   I bought step studs recently from a Boston company...   Jul 22 2011, 08:21 PM
geniusanthony   I actually read your post, I have a 1/4" driv...   Jul 22 2011, 08:23 PM
HAM Inc   Get some 911 exhaust nuts. They are internal wrenc...   Jul 22 2011, 08:26 PM
914Mels   Is your stud still a 8mm? Nuts with a 12mm head ar...   Jul 22 2011, 09:17 PM
porsche913b_sp   Get some 911 exhaust nuts. They are internal wren...   Jul 22 2011, 09:18 PM
porsche913b_sp   Is your stud still a 8mm? Nuts with a 12mm head a...   Jul 22 2011, 09:21 PM
Dave_Darling   He's just saying that the nut takes a 12mm wre...   Jul 22 2011, 09:45 PM
porsche913b_sp   He's just saying that the nut takes a 12mm wr...   Jul 22 2011, 10:01 PM
ArtechnikA   The nut head is 14mm. So I dont think the 911 exh...   Jul 23 2011, 05:01 AM
SirAndy   Get the stud out and use a bolt with a allen head ...   Jul 22 2011, 10:13 PM
porsche913b_sp   Get the stud out and use a bolt with a allen head...   Jul 22 2011, 10:37 PM
HAM Inc   9mm nuts (requiring a 14mm socket) are very uncomm...   Jul 23 2011, 07:30 AM
GeorgeRud   Though you would have to drop that side's exha...   Jul 23 2011, 08:45 AM
HAM Inc   If the stud is in securely I wouldn't fool wit...   Jul 23 2011, 09:21 AM
porsche913b_sp   So I went to local OSH and figured the stud is 3/8...   Jul 24 2011, 01:00 PM
HAM Inc   The alloy steel will be fine, and they are cheaper...   Jul 24 2011, 07:01 PM
porsche913b_sp   Thanks HAM !!   Jul 24 2011, 09:38 PM
porsche913b_sp   So the good news I found the allen nut and was abl...   Jul 31 2011, 08:04 PM
- Lo-Fi Version Time is now: 31st October 2024 - 08:25 PM
