SS HE wont fit on head. Please help !, PO had replaced head stud with bigger one |
913B |
Jul 22 2011, 08:15 PM
Senior Member Group: Members Posts: 852 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
It had to the be studs where the HE bend is. The replacement bolt and screw is just too close to the heat exchnager pipe. It was ok when the previouse owner just had stock HE. But the SS HE are bigger and I cannot get a socket around the replacement nut.
Whats my options ? Hope and try to locate smaller nut at local Home Depot or McMaster I even thought about taking the HE to someone to heat it up and make a slight indention in it to give me more room. Am I screwed. Any thoughts. Thanks so much. Ted |
GeorgeRud |
Jul 23 2011, 08:45 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Though you would have to drop that side's exhaust, you should be able to effect the repair with the engine in the car.
If the stud is in fact an 8mm one, simply use the barrel nut from the 911. If it was tapped to a larger size, a stepped stud is the way to go. I've always found that, if in doubt, McMaster-Carr is your friend when you need to find some really obscure piece of hardware. |
Lo-Fi Version | Time is now: 31st October 2024 - 08:24 PM |
